Site Search
To get started, click here.
How to replace the Oil Seal Kit for gearcase input shaft on a Whirlpool Direct Drive Washer
Posted by Samurai Appliance Repair Man, in Washing Machine Repair 13 December 2012 · 2,232 views
whirlpool, washer, top load and 2 more...
Y'all go grab a brewski and kick back while Professor jumtrout 'splains it to us...
Remove the cabinet.
Lay the machine on its back.
Remove the pump and motor.
Remove the drive coupling on the transmission.
Remove the motor mounting plate from the transmission.
Remove the seal as described below...
To remove the seal,I use a drywall screw.
Use your electric drill to run the screw in at the 2 o'clock position through the seal.
The screw will hit the gearing behind the seal and pull the seal out.
Use a 3/4 socket to seat the new seal.
And here's the part link for the oil seal kit you'll need ==> http://www.repaircli...l/285352/470681
The kit comes with two different seals so it can work with different Whirlpool-built D/D transmissions. Use the one that's made for your transmission. Match 'em up by sight.
Source: Kenmore 90 Series Washer 11020922990 Oil Leak
How to replace the heating element in an electric hot water heater without draining the tank
Posted by Samurai Appliance Repair Man, in Water Heater 13 December 2012 · 4,110 views
water heater, element
If you need to replace the heating element in your electric water heater, you may be thinking that you need to first drain the tank. You could do it that way but the Old Timers would shake their head at you and think, "What a rube."
Below, a few of the Master Appliantologists here at the Academy offer some tips and procedures for repalcing the heating element with a tank full and not making a flooded mess:
Quick and dirty water heater element change
turn off power to heater
turn off water to heater or house
re-leave pressure anywhere you want but when it's gone close the valve (sink , tub ect )
remove cover and disconnect wires
get new heater element ready , remove from package , put on gasket ect
put big towel down in front of heater
loosen old element with wrench about a half turn
hold new element in one hand , unscrew old element with the other , and switch them out quickly ( make sure as your unscrewing the old element the o ring comes with it )
use wrench to tighen , hook up wires ect , your done
if done right you will loose less than a glass of water on the floor
always leave yourself the out if things go wrong of reversing and putting the old element back in , if you can't get the threads to start or something like that
I have done hundreds this way and even the old 4 bolt type with no problems at all
I change all my elements without draining.
You lose almost no water.
However,keep a towel and shop vac close by.
The only problem comes in when it is a old corroded element and the rubber gasket wants to stick in the hole.
Other times,the element is busted and hangs up coming out.
If the gasket sticks,remove the new gasket from the replacement element and re-use the old gasket.
NOTE: You can not drain a heater from the high temp pop valve.
I change the element with out draining the tank... Turn off the power........Shut off incoming supply line........Open the hot side of the faucet to relieve the pressure then close the valve..............Loosen the element a few turns and you should be able to see if the gasket is stuck to the tank, just use a small flat bladed screwdriver to pry loose....... have the new element in hand as you remove the old one........ when removed, just drop it and insert the new one......you are lucky if the customer has their tank sitting in a drip pan...... :thumbsup: ..........If you need to remove the water, disconnect the incoming line and the outlet side..................................Use some compressed air on the outlet side ( draw tube high in tank )...... water level will be expelled out the incoming side to the level of the fill tube ( lowest point )..... Not all of the water will be out , BUT, it will be lighter.......
Source: suggestion for new electric water heater?
LG Refrigerator Compressor Start Relay Madness
Posted by Samurai Appliance Repair Man, in Refrigerator Repair 13 December 2012 · 2,418 views
LG, refrigerator, start relay and 1 more...
Every now and then, you run into a real CF when you're trying to order a part to fix an appliance. A case in point is trying to get a start relay kit for some models of LG refrigerators, such as the LFX25960ST.
Grand Master kdog, adept extroidinaire of all things appliance repair, explains how to de-frak this mess:
I had the exact issue with the same model # before - this got me out of it.
The components do not all show up on the literature - at the time I was working for a very large company that had alot of pull with LG and I begged them to contact LG to correct this issue for future folks that get caught.
I did not replace the capacitor as it was not required
One of the prongs on the relay will just be unused - no biggie, I knew this because i was sent to the fridge with a control board that had been ordered and overnighted (very costly delivery) - just to find out there was no issue with the board, can't just look at the lady and say I need to order parts again (no fridge!), rummage around in truck and find replacement by eyeball matchup (no app for that).
I should expand on that a bit - I recognized the particular model of Embraco compressor that I have seen many times in W/P built fridges and went from there.
Relay terminals are all numbered
Here's the link to the start relay you need ==> http://www.repaircli.../4387835/586449
Source: LG Fridge Model# LFX25960ST, Totally Stumped!
Like - Plus - View - Connect
Facebook-icon50x50.png google-plus-icon-50x50.png YouTube-icon50x50.png linkedin-icon-50x50.png
Find Parts & Diagrams Here
Search My Blog
Latest Visitors
Random Album Image
Dryer Fire
16 user(s) viewing
0 members, 16 guests, 0 anonymous users
