    1,398
    2,717,902
How to replace the door latch assembly in an LG Tromm Washing Machine
no need to take front panel off. remove spring that holds gray door boot in place. look around the edge you'll find the spring you pull to stretch. peel back boot remove screws from switch disconnect wires and you're all set.
Click to buy the door latch assembly. One year warranty.
Source: LG Trom Washing Machine WM0532HW
