    1,398
    2,719,593
How to install a new water inlet valve in a Bosch WFMC front-loading washer
- unplug washer
- turn off water supply at shut off valve on the wall
- unscrew the water fill hoses from the washer
- remove three torx screws in the back of the top panel
- panel pull back and lifts off
- water inlet valve is right there, remove obvious screws and wire harnesses and install the new valve
Cold water valve:
Click image to purchase.
Hot water valve:
Source: Bosch WFMC3200UC Washing Machine
