    1,398
    2,718,850
Replacement analog pressure switch for the Whirlpool Duet Steam washer to fix F35 and "SUDS" errors
The original pressure switch for this washer has been discontinued which has created a conundrum for those with the F35 or SUDS error codes. Here's the work-around:
Well the part number W10312527 is a replacement with a little work.
(maybe just a plastic key tab on the connector that could be cut off?).
that is correct, the tech had to snip a little plastic off so the key type insert would fit.
The machine worked fine with this part. The washer was a Whirlpool WFW9600TW00
Good Luck
Part Link ==> Pressure Switch
Source: Analog Pressure Switch... F35..SUDS
