    1,398
    2,719,246
How to replace the thermal fuse in a Maytag Neptune MDG6800AWW dryer
Open the door and remove the 2 phillips screws in the hinges (item 20),
remove the 2 phillips screw on the opposite side where the hinges
would be if the door was reversed (item 35)
Flex the 2 upright pieces of item # 22 and pull forward and remove.
The front bulk head item # 29 is held in place with (2) screws on each side.
You will notice that there are 3 screws on each side but one of them on each
side only hols the bulk head together..doesn't actually attach it to the frame.
Once the screws are remove the screws and brackets item # 27.
Now you can raise the top about 2" and pull the bulk head off.
There will be door switch wires attached...you can either leave them in place
or disconnect from the door switch...just remember their locations.
The thermal fuse is item # 40...It will be attached to item # 43 should read "closed" with your meter
or 0 continuity.
If this is the culprit make sure you clean the bulk head / filter housing
as well as check your venting thuroughly for a clogg or restriction.
Thermal Fuse Link
900
900
Source: Maytag Neptune Dryer Model # MDG6800AWW
