    1,398
    2,717,992
How to troubleshoot a Panasonic microwave oven with an H95 error code
Master appl.tech offers these tips:
Ensure your filament leads on the magnatron aren't open (open = bad)
need to verify that your getting 120V to the inverter (if not = bad board)
the 2 signal wires to the inverter should be showing 3VAC from the board (if not = bad board)
If the above all check good then you have a bad inverter.
Source: Panasonic Microwave NN-SD277W
