    1,398
    2,719,202
How to fix a Whirlpool Duet washer with an F06 error code
appl.tech.29501 wrote:
An F06 is usually the motor control board. And yes there could be a bad connection at the plug. You can pull the motor control out and inspect the solder joints on the board. Although usually the board will require replacement I have heard of people cleaning the board and connections with electronics cleaner and the problem was solved.
http://www.repaircli...8182706/1184161
Source: whirlpool duet #ghw9300pw
