How to fix a Samsung DMR57 or DMR78 dishwasher making a grinding noise and error code 9E
Posted by Samurai Appliance Repair Man, in Dishwasher Repair 05 October 2011 · 2,058 views
Samsung dishwasher 9E grinding noise
Sublime Master john63 reveals the kata for this encounter:
<<<There is a grinding noise when first started up>>>
Many Samsung DMR57 & DMR78 dishwashers are known for developing a rattling/grinding noise during DRAIN MODE.
This is usually caused by a broken plastic mounting tab from the upper rack ADJUSTERS.
Each side of the upper rack has a tan/gray square RACK ADJUSTER---after a mounting tab (or 2) breaks off---this piece of plastic eventually ends up in the DRAIN PUMP HOUSING.
The DRAIN MOTOR should be removed to inspect for debris.
<<<after a minute or two I get 9e error code>>>
A normal amount of water in a DMR78 dishwasher would be---at about 1 inch past the HEATER SHIELD in the tub.
If you've tested the SWITCHES on the LOW LEVEL SENSOR---then they're not at fault.
Press the following buttons at the *same* time:
DELAY START--NORMAL--POWER(button)
The word "ALL" appears for 3 seconds followed by  "t1"
(NOTE: Test #1 checks the functions of the INLET VALVE--FLOW METER--LOW LEVEL SENSOR)
Press the DELAY START button---the DRAIN MOTOR will run for 45 seconds. Then---water will enter the tub.
When the PULSE COUNT (on the display) reaches "660" or greater---press the NORMAL button four times.
A flashing "t5" will be displayed & water will drain for 30 seconds. After 30 seconds---the "t5" will stop flashing.
Press the NORMAL button again---"t6" will be displayed. The word "OFF" should appear in the control panel display---indicating that the LOW LEVEL SENSOR SWITCH is in the correct position for *No Water* in tub.
If the INLET VALVE--LOW LEVEL SENSOR--FLOW METER function normally----replace the MAIN BOARD.
Source: Samsung dmr78ahs dishwasher  grinding noise and error code 9e
No Model Number, No Help!
