    1,398
    2,718,670
How to check the motor on a Maytag Neptune MAH5500BWW washer
Grand Master RegUS_PatOff tiptoes us through these tulips:
Motor Windings Check
1 . Disconnect power to the unit.
2 . Remove each pair of phase wires from the motor control and perform an ohm check of each wire leading to the motor.
Each wire pair should show 2-3 ohms resistance.
2 . There should be no continuity between any of the terminals and the frame of the motor.
3 . Check that all six motor terminals are secure and at the same height in the connector housing.
Replace motor if terminals are pressed into the motor.
4. Remount the six-position motor connector onto the motor.
Reassemble the drip shield cover onto the motor control.
5 . Reposition the motor control into the washer when finished.
Make sure the two screws and the twistlock wire ties are fastened properly to the wire harness.
Service Bulletin
TDL-0043A-B.pdf
Motor and motor control board part link ==> Motor and Control Module
Source: Maytag MAH5500BWW s/n 74919775ZZ
