Ultimate Appliance Gift Ideas
The Samurai has scoured both the Innernet AND the Outernet rounding up those perfect Christmas, Hanukah, Kwanzaa, and Festivus gift ideas for that special Fixer Dude or Dudette in your life. Click the photos for more info or to purchase.
Stay warm AND safe with this Pocket Air Check combustible gas leak detector. Works with Natural and LP gas.
Multimeter. The indispensable tool for every DIYer. Specs: Volts AC 750 , Volts DC 1000, Amps AC 10, Resistance max. (Ohms) 2M, Continuity, Temperature -4 °F to 2498° F, Display (Counts) 2,000, Operating Temperature 32° F to 74° F (0°C to 23°C), Fuse Protection mA: 0.2A/ 250V, Power 9 V Battery (included), Size 5.5"L x 3"W x 1.5". Temp probe included.
Non-contact A/C voltage detector. Test for voltage without touching any bare wires. This detector works by sensing voltage through the wire's insulation. Detector has an audible beeper and visible flashing light indicator.
3 in 1 tool for splicing wires. Has wire strippers for stripping off insulation from the wire. Crimpers for crimping solderless connectors and bolt cutters for cutting small bolts. High quality.
240 Volt 240 Volt outlet checkers for checking the outlets on electric ranges and dryers.
Dryer Vent Tester for testing the backpressure on a dryer vent. Excessive backpressure is the single most common cause of overly long dryer times, repeatedly blowing thermal fuses and poor dryer performance. A vent can be free of lint and still be bad! Use this spiffy tool to check your dryer vent. A must-have if you're a pro in the trade.
Microwave leakage detector.
Refrigerator and freezer thermometer, temps from -20 to 80 degrees Fahrenheit. Thermometer face has special markings to show where food is safe and where it is at risk of spoilage.
The Kill-A-Watt Energy Usage Meter. This plug-in meter allows you to track total power consumption by hour, day, week, month, or year. Also displays Voltage (V), Line Frequency (Hz), and Power Factor (PF). 15 amp maximum. No batteries required. Accepts standard 110 volt plugs, 2 or 3 prong.
Freezer alarm, sounds if freezer temperature goes above 15 degrees. Never lose expensive frozen foods again!
Gasohol tester. Used to test the alcohol content in the fuel.
Polder 3 function thermometer: large LCD read out displays the temperature of food during cooking. Presettable HI/LOW and inside the range temperature alert. Timer: 24 hour count down and count-up. Clock: Real-time clock. Stainless steel probe. Temperature chart and battery included.
Glide n Guard floor protector for appliance moving.
Affresh HE Washer Cleaner Pack - Use once a month to keep your HE (high efficiency) washer clean and odor-free! 3 Power Puck tablets and 4 Grit Grabber cloths per box.
Affresh Dishwasher and Disposal Cleaner - 6 Tablets.
Glisten dishwasher cleaner
Refrigerator and freezer condenser coil cleaning brush with instructions. Also works great for dryer lint.
Solid-surface range element cleaner (Sponge no longer included).
Vacuum cleaner attachment for condenser and dryer cleaning - This long vacuum cleaner attachment will help to clean dust and lint build-up in and around your refrigerator condenser coils underneath the refrigerator and dryer lint in the area where the lint filter is inserted. Fits 1-1/4 inch vacuum hose.
Dryer vent cleaning brush. For 4" diameter round ducts. 20 feet long.
Complete Ceramic Cooktop Care Kit - contains a 10 ounce Cooktop Cleaner to clean and polish all glass or ceramic cooktops. A 4 ounce bottle of Cooktop Protectant. Six small cooktop cleaning pads and one larger Cooktop Protectant applicator.
Stainless steel cleaner.
Gas grate cleaner.
Rust remover - Removes rust stains from clothes, dishes, glassware, kitchen and bathroom fixtures, painted surfaces, concrete and water softeners. 16-ounce bottle.
- DurhamAppliance likes this
Create a custom theme
