Ultimate Appliance Gift Ideas
Posted by Samurai Appliance Repair Man, in General Appliance Repair Wisdom 14 December 2011 · 607 views
The Samurai has scoured both the Innernet AND the Outernet rounding up those perfect Christmas, Hanukah, Kwanzaa, and Festivus gift ideas for that special Fixer Dude or Dudette in your life.  Click the photos for more info or to purchase.
Stay warm AND safe with this Pocket Air Check combustible gas leak detector. Works with Natural and LP gas.
Multimeter.  The indispensable tool for every DIYer.  Specs: Volts AC 750 , Volts DC 1000, Amps AC 10, Resistance max. (Ohms) 2M, Continuity, Temperature -4 °F to 2498° F, Display (Counts) 2,000, Operating Temperature 32° F to 74° F (0°C to 23°C), Fuse Protection mA: 0.2A/ 250V, Power 9 V Battery (included), Size 5.5"L x 3"W x 1.5". Temp probe included.
Multimeter - Part # 964740 Mfg Part # DM10T
Non-contact A/C voltage detector. Test for voltage without touching any bare wires. This detector works by sensing voltage through the wire's insulation. Detector has an audible beeper and visible flashing light indicator.
Voltage Tester - Part # 1255942 Mfg Part # 1000100009
3 in 1 tool for splicing wires. Has wire strippers for stripping off insulation from the wire. Crimpers for crimping solderless connectors and bolt cutters for cutting small bolts. High quality.
Wire Splicing Tool - Part # 967613 Mfg Part # 1002
240 Volt 240 Volt outlet checkers for checking the outlets on electric ranges and dryers.
Tool - Part # 1176379 Mfg Part # 4396932
Dryer Vent Tester for testing the backpressure on a dryer vent.  Excessive backpressure is the single most common cause of overly long dryer times, repeatedly blowing thermal fuses and poor dryer performance.  A vent can be free of lint and still be bad!  Use this spiffy tool to check your dryer vent.  A must-have if you're a pro in the trade.
Tool - Part # 1447456 Mfg Part # W10106710
Microwave leakage detector.
Microwave Test Kit - Part # 1668485 Mfg Part # A138
Refrigerator and freezer thermometer, temps from -20 to 80 degrees Fahrenheit. Thermometer face has special markings to show where food is safe and where it is at risk of spoilage.
Thermometer - Part # 903650 Mfg Part # 8171720
The Kill-A-Watt Energy Usage Meter. This plug-in meter allows you to track total power consumption by hour, day, week, month, or year. Also displays Voltage (V), Line Frequency (Hz), and Power Factor (PF). 15 amp maximum. No batteries required. Accepts standard 110 volt plugs, 2 or 3 prong.
Energy Usage Meter - Part # 1012487 Mfg Part # P4400
Freezer alarm, sounds if freezer temperature goes above 15 degrees.  Never lose expensive frozen foods again!
Freezer Alarm - Part # 786349 Mfg Part # 8171458
Gasohol tester.  Used to test the alcohol content in the fuel.
Gasohol Tester - Part # 1611245 Mfg Part # 795161
Polder 3 function thermometer: large LCD read out displays the temperature of food during cooking. Presettable HI/LOW and inside the range temperature alert. Timer: 24 hour count down and count-up. Clock: Real-time clock. Stainless steel probe. Temperature chart and battery included.
Digital Meat Thermometer - Part # 905158 Mfg Part # 601-90
Glide n Guard floor protector for appliance moving.
Floor Protectors for Moving Appliance - Part # 12914 Mfg Part # 93001
Affresh HE Washer Cleaner Pack - Use once a month to keep your HE (high efficiency) washer clean and odor-free! 3 Power Puck tablets and 4 Grit Grabber cloths per box.
Cleaner Kit - Part # 1914804 Mfg Part # W10306172
Affresh Dishwasher and Disposal Cleaner - 6 Tablets.
Dishwasher and Disposer Cleaner - Part # 1552531 Mfg Part # W10282479
Glisten dishwasher cleaner
Dishwasher Cleaner - Part # 1915432 Mfg Part # 5304482929
Refrigerator and freezer condenser coil cleaning brush with instructions. Also works great for dryer lint.
Long Handled Bristle Brush - Part # 12859 Mfg Part # 5303318693
Solid-surface range element cleaner (Sponge no longer included).
Solid Surface Element Cleaner - Part # 12830 Mfg Part # 5303310267
Vacuum cleaner attachment for condenser and dryer cleaning - This long vacuum cleaner attachment will help to clean dust and lint build-up in and around your refrigerator condenser coils underneath the refrigerator and dryer lint in the area where the lint filter is inserted. Fits 1-1/4 inch vacuum hose.
Vacuum Hose Attachment - Part # 1544893 Mfg Part # 8171579A
Dryer vent cleaning brush. For 4" diameter round ducts. 20 feet long.
20 Foot Vent Cleaning Brush - Part # 424663 Mfg Part # 18001034
Complete Ceramic Cooktop Care Kit - contains a 10 ounce Cooktop Cleaner to clean and polish all glass or ceramic cooktops. A 4 ounce bottle of Cooktop Protectant. Six small cooktop cleaning pads and one larger Cooktop Protectant applicator.
Glass Cooktop Cleaner - Part # 959474 Mfg Part # 31605
Stainless steel cleaner.
Stainless Steel Cleaner - Part # 1542817 Mfg Part # 31462A
Gas grate cleaner.
Grate Cleaner - Part # 496592 Mfg Part # 316119700
Rust remover - Removes rust stains from clothes, dishes, glassware, kitchen and bathroom fixtures, painted surfaces, concrete and water softeners. 16-ounce bottle.
Rust Remover - Part # 1550725 Mfg Part # W10278629
Nice !
Tips from Mayor Bloomberg for Surviving a Gun Attack by a Crazed Criminal
