How to fix an LG washer that won't pump out and throws an OE error code
Posted by Samurai Appliance Repair Man, in Washing Machine Repair 04 January 2012 · 957 views
Most likely a failed DRAIN MOTOR, part number 4681EA2001D
Water drains from the tub...
Through the hole at the bottom of the tub (almost never a restriction/blockage will occur here)
Through the black bellows type hose---into the PUMP HOUSING (once-in-a-while a sock may be in this bellows)
From the PUMP HOUSING---through the STRAINER---into the PUMP MOTOR/IMPELLER housing (coins/buttons/pins/bra wire/BBs/lint etc can accumulate in *both* the STRAINER and the IMPELLER area of the PUMP MOTOR).
Drain water is then forced/pushed through the DRAIN HOSE mounted at the top of the PUMP ASSEMBLY. In some cases---rubber-backed bathroom floor mats have disintegrated during the wash cycle and have COMPLETELY plugged the drain system from the entrance to the PUMP HOUSING----to the gray DRAIN HOSE---a solid mass of sandy/rubbery residue.
As the DRAIN HOSE runs from the PUMP HOUSING to the white-plastic (u-shaped) GOOSENECK CONNECTOR (mounted on the rear of the washer)---water reaches the DRAIN STANDPIPE or UTILITUB.
Blockage can occur at the GOOSENECK---and compressed air is most effective at blowing this small connector free of debris.
<<< I then tried to send it through a quick rinse/spin cycle (19 minutes)>>>
Try this...
1) Press: POWER Button (wake-up washer)
2) Press "SPIN SPEED" button---set to NO SPIN
3) Push "START/PAUSE" button
Washer will enter DRAIN CYCLE (pump all water from tub---when operating properly) and shut off after one minute.
<<<This pump WAS running BEFORE i took it apart. I remember running it through a cycle and hearing it suck through the filter plug.>>>
It's not unusual at all to find a DRAIN MOTOR that "runs" but is too slow (or the impeller is loosely spinning) to effectively drain the wash water out.
Verify first---that no other restriction/blockage is preventing drain.
If the DRAIN MOTOR fails to function consistently---replace it.
<<<The full wash cycle with laundry did fail. I had an OE on it>>>
"OE"====> No Drain---replace DRAIN MOTOR.
LG part number: 4681EA2001D
Appliance Parts Pros part number:  AP4437652
<<<this time there was fabric softener remaining>>>
This tells us only that the DRAIN MOTOR failed while attempting to pump out water from the Main Wash (did not advance to the *Rinse* portion of the cycle)---dirty wash water remaining in the tub---triggered an "OE" error. Cycle will *not* advance any further.
<<<is there possibly some other electronics piece not properly running the cycles?>>>
No.
Additionally---there are no SERVICE BULLETINS either---which would indicate/describe *software* issues.
An intermittent DRAIN MOTOR can give the appearance that something else is causing the "OE" error.
Part link ==> Drain Pump
Source: LG WM2016CW OE error won't pump in rinse mode
Removing the door on a Whirlpool range model SF305PEEN
