    1,398
    2,718,862
How to manually unlock a stuck door on a Whirlpool Duet HT front loading washer
Normally, after removing power, it may take up to 3 minutes for the door to unlock
Manually Unlocking the Door Lock System:
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard.
6. The door may be opened.
Source: Whirlpool Duet HT Front Loading Washer GHW9400PL Locked Up!
