How to replace the drain pump on a Maytag MAH2400AWW front load washer
Posted by Samurai Appliance Repair Man, in Washing Machine Repair 11 March 2012 · 1,488 views
Maytag Washer MAH2400AWW pump Drain pump
from the service manual (if needed)
Drain Pump Removal
1. Disconnect power supply to unit.
2. Gain access to bottom of unit.
3. Remove 4 screws securing panel to the bottom of the cabinet.
4. Remove drain hose and tub hose from pump.
5. Disconnect electrical connector .
6. Remove 4 screws and slide pump mounting bracket to free tabs and remove motor.
Part link to the drain pump ==> http://www.repaircli...mber=MAH2400AWW
Service Manual for this washer ==> http://appliantology...compact-washer/
Source: Maytag Washer Model #MAH2400AWW
Burnt Power Wire Connections In A Dishwasher Junction Box
