Troubleshooting tip for fixing an Amana NED7200TW (Samsung-built) electric dryer that's not heating
Amana dryer Samsung no heat thermistor
A SAMSUNG-built dryer.
The temperature THERMISTOR should show 10,000 ohms at 77F
If not---replace it.
In nearly all cases where the THERMISTOR has failed---the *coating* on it has become damaged and the tiny copper winding has a green color (corrosion). This is especially common in areas near a salt-water environment (beach/shore).
See image: http://www.repaircli...200tw-%3d%3dc61
Also inspect the TERMINAL BLOCK (where plug is attached to dryer) for loose/burnt connection(s).
Here's the part link for the thermistor ==> http://www.repaircli...ber=NED7200TW10
And, for reference and enrichment, here's the schematic for this dryer:
Click for large view - Uploaded with SkitchSource: Amana NED7200TW Dryer no heat, problem with cycling thermostat?
- kdog likes this
Create a custom theme
