Tip for removing the top panel and tub from the NEW versions of the Whirlpool Cabrio washers
whirlpool cabrio washer maytag bravo kenmore oasis tub hub nut top panel
This isn't the normal Cabrio, this is the new version that is not a direct drive and lacks a recirculation pump. The proper removal of the top involves taking the hinge screws and other screws off the back and pulling the top forward a bit than up to clear a tab on each side. IMO it's a stupid design
The basket is removed by removing the spanner nut, its that galvanized thing maybe 2.5 inches in diameter just above where you took the 6 screws out.The original whirlpool direct drive spanner wrench will work or use a punch and hammer.
Put the 6 screws back in the basket hub before you try to pull the basket.
- I wish those shit heads at Whirlpool had not called this a Cabrio...it's confusing the customers, salespeople, and service staff too.
Source: Cannot release top spring clips on Whirlpool WTW5600XW0 Cabrio
Create a custom theme
