Samsung washer OE error code
Posted by Samurai Appliance Repair Man, in Washing Machine Repair 14 April 2012 · 1,594 views
An "OE" error indicates that the MAIN BOARD received data-feedback from the WATER LEVEL SENSOR---that an *overflow condition* occurred (too much water in tub).
When this error is detected---the DRAIN MOTOR will automatically begin pumping/draining the water from the washer until the water level is below the *overflow" level.
Usually the fault will be caused by one of two components:
1) Faulty WATER LEVEL SENSOR.
2) Failing/faulty WATER INLET VALVE---keeps filling water intermittently when valve should be "off".
There are two sets of WATER VALVES---one for Hot Water and one for Cold Water.
Buy Samsung washer parts with a 365-day return policy here ==> http://www.repaircli...g-Machine-Parts
Source: Samsung WF328aaw-02 - Keep Losing Main PCB - OE Error
Figure 8
