Maytag Neptune washer with a tE error code
Maytag Neptune washer tE mah6700aww
lower case t E ?
Sump thermistor failure
Thermistor
Unplug harness connector and test from wire insertion side of connector.
Pin #6 and Pin #3 of CN3
13K ohms @ 70F (2.5V DC)
Yes---as RegUS mentioned---the "tE" error is a Thermistor Error.
Can be caused by:
1) Corroded plug connection at THERMISTOR (common)
2) Failed HEATER (can be tested for continuity with a test meter)
NOTE: The THERMISTOR can be access from the bottom of the washer---if an assistant can tip the washer back.
The location of the *bullet-shaped* sensor is at/near the 6 o'clock position on the front of the tub.
Part link for the thermistor with a 365-day return policy ==> http://www.repaircli...918?RCAID=24038
Source: mah6700aww gets upside down F and E error code
Create a custom theme
