LG washer giving a tE error code
Posted by Samurai Appliance Repair Man, in Washing Machine Repair 01 May 2012 · 1,715 views
LG washer tE
<<<I have a wm2487hwm giving me the "te" code. I examined the wiring. ohmed the thermistor out at 67.5kohms>>>
The wash tub THERMISTOR should show 39.5 K ohms at 86 F.
I've never encountered a failed THERMISTOR on an LG washer.
A "tE" error is usually caused by a broken/failed wire at the plug which connects to the THERMISTOR at the front/bottom of the tub. This plug should be examined very carefully for a break in either the *white* or *blue* wires at the connector.
In some cases---the break in the wire will be *internal* and not visible.
It is necessary to perform a *continuity test* for both wires---from the plug/connector at the MAIN BOARD-to-the-plug/connector at the THERMISTOR. Have an assistant move/bend/flex the plug (at the Thermistor) to verify that the wiring is intact.
Test the HEATING ELEMENT next to the THERMISTOR---should show 12 to 18 ohms.
<<<put the machine back together and now it's totally dead!>>>
Verify that *all* of the plug/connectors behind the "jog dial" (Control Panel) have been re-connected (fully & competely until it locks).
NOTE: This washer is a *steam wash* model.
If an error "tE 2" is displayed---this would indicate that there's an issue with the THERMISTOR at the STEAM
GENERATOR (at the top of the tub assy).
Source: LG Front Load Washer TROMM
Like - Plus - Connect - View
LG Dishwasher Sump Assembly Teardown, 11 of 12
21 user(s) viewing
0 members, 21 guests, 0 anonymous users
