Jenn-Air downdraft range undocumented error codes EE-214 M-214
Jenn-Air range error code fault code
This is a fault code that never made it to the tech sheet. Faulty Touch Pad is the cure. I have it written in pen on my fault sheet so it has to be correct!!
FYI for our staff, that clock is in the wall oven line as well. Same thing will apply to any unit that uses that ATM style control. It is not in any publication.
Buy Jenn-Air range parts with a 365-day return policy here ==> http://www.repaircli...tove-Oven-Parts
Source: jenn air downdraft range error codes EE-214 M-214
- kdog likes this
Create a custom theme
