Fixing a Whirlpool VM Washer that gets Stuck in the Cycle
Whirlpool VMW VM washer washer
http://www.youtube.com/watch?v=Ud8wybYmvyk
This customer is on a well (dug well, not a drilled well) and doesn't use any sediment filters in her water supply. The hot water side is never a problem because the hot water tank acts like a settling basin. Can you imagine what the inside of that hot water tank looks like? So the solution is to install a simple sediment filter in the water supply that can be changed as needed and protects the water heater and all wet appliances.
The Appliance Guru offers fast, expert appliance repair service in New London, NH. For fast, expert appliance repair service, call 526-7129. More info at www.ApplianceGuru.com
Create a custom theme
