How to replace the Oil Seal Kit for gearcase input shaft on a Whirlpool Direct Drive Washer
Posted by Samurai Appliance Repair Man, in Washing Machine Repair 13 December 2012 · 1,704 views
whirlpool washer top load gearcase oil seal
Y'all go grab a brewski and kick back while Professor jumtrout 'splains it to us...
Remove the cabinet.
Lay the machine on its back.
Remove the pump and motor.
Remove the drive coupling on the transmission.
Remove the motor mounting plate from the transmission.
Remove the seal as described below...
To remove the seal,I use a drywall screw.
Use your electric drill to run the screw in at the 2 o'clock position through the seal.
The screw will hit the gearing behind the seal and pull the seal out.
Use a 3/4 socket to seat the new seal.
And here's the part link for the oil seal kit you'll need ==> http://www.repaircli...l/285352/470681
The kit comes with two different seals so it can work with different Whirlpool-built D/D transmissions. Use the one that's made for your transmission. Match 'em up by sight.
Source: Kenmore 90 Series Washer 11020922990 Oil Leak
Like - Plus - Connect - View
Roger Gillespie in the Daily News
43 user(s) viewing
0 members, 42 guests, 0 anonymous users
Yahoo (1)
