    1,398
    2,719,748
Inverter Motor Fuse Eliminated from GE Hydrowave Top-Load Washers
From the GE Tech bulletin on this:
New variable speed inverter motors no longer
require the in-line fuse. When replacing an
older Hydrowave inverter motor with the new
inverter motor, the in-line fuse must be
removed from the washer harness. Failure to
remove this fuse link will cause the fuse link to
fail due to the higher inrush current of the new
motor design.
Replacement motors will include a jumper wire
and 2 wire splices to remove the in-line fuse.
Read more: http://appliantology.org/topic/41994-ge-wjre5500goww-washer/#ixzz2SpWjBMAt
You can download the tech bulletin here: http://appliantology.org/files/file/817-ge-service-bulletin-new-variable-speed-motors-on-hydrowave-washer-fuse-removed/
Buy parts for your GE washer here: http://www.repairclinic.com/GE-Washing-Machine-Parts
