    1,398
    2,718,930
How to get the error codes on an Electrolux dishwasher
Brother PDuff calls the dance steps on this little ditty:
Remove bottom access panel and check main control for any lit leds. Lit led is specific to affected component. Access Component/Relay/Triac test as follows:
From power up press Sanitize and Delay Start
"Et" should be displayed (engineering test)
Press Rinse Only
"rt" should be displayed indicating component test mode. Press the following buttons to toggle on/off each component:
Auto Sense-washer motor
Heavy-water valve
Normal-drain motor
Quick-drain valve
Rinse Only-Clean light led
Hi Temp-all leds on control housing
Sanitize-fan state
Air Dry-dispenser
When checking heater, always fill tub with water.
Source: Frigidaire D/W EIDW6105GB1
1 Comment
All you have to do to get error codes on an Electrolux is try to wash your dishes with the damn thing.
Link to comment
