    861
    1,396
    2,681,486
How to run the field service test for a Jenn-Air JDB1100AWS dishwasher
Float Switch only controls the Water Valve
Field Service Test
A Field Service Test may be started by pressing the key 5 times followed by the key within 6 seconds.
This test must be performed with clean water to insure proper sensor performance.
“88” will appear in the display (if available*) and the following sequence of events will occur:
SECONDS . . . . . FUNCTIONS / ACTIVE LOADS
106 . . . . . . . . . . .Water Valve
5 . . . . . . . .. . . . .Thermistor check / Turbidity Sensor check & Calibration - no loads active.
120 . . . . . .. . . . . Wash Motor / Dispenser Wax Motor
180 . . . . . . . . . . .Wash Motor / Heater
120 . . . . . .. . . . . Drain Pump
4 . . . . . . . . . . . . .Water Valve
For manuals and lots of other goodies,
Source: Jenn-Air JDB1100AWS dishwasher - water left in basin after cycle
