    861
    1,395
    2,675,813
How to Disassemble the Dispenser in an LG Refrigerator
Brother Chat calls the dance steps on this one. This particular case is for model number LSC26905TT but the same procedure applies to many other LG models, too.
1) Disconnect funnel and button assembly by pulling down and forward.
2) Remove display frame Assembly by making a gap between a display frame Assembly and funnel Assembly. with a balde screwdriver and pulling it forward. The cover dispenser is attached with a hook.
3) The Display Assembly can be connected by pressing the top of the dispenser cover and pushing it after separating the Display Frame from its housing.
4) Loosen four screws with a phillips screwdriver and pull the funnel Assembly to disconnect.
5) The Duct Cap Assembly can be disconnected if the hold lever connecting screw is loosened with a phillips driver.
6) To install the Duct Cap Assembly, insert one end of the spring into the right hole of the dispenser lever and insert the other end into the right hole in the top part of the dispenser. Then attach the holder at the solenoid switch.
http://appliantology.org/files/file/268-lg-lsc26905-fridge-service-manual/
You'll have to subscribe to download above service manual.
Source: lg lsc26905tt
