    861
    1,396
    2,681,656
How to build your own custom library of tech documents on a Kindle Fire, iPad, or other tablet in 4 easy steps!
Having the right technical document with you on a service call and knowing how to use it are the two key ingredients to getting an appliance properly diagnosed and repaired.
Does that mean that you should try to find a mobile device that is already pre-loaded with appliance repair technical documents? There are several downsides to this approach, including the fact that you don’t know how current or relevant the pre-loaded docs are.
Instead, you can easily create your own information arsenal using a tablet of your choice and the powerful resource we describe in this video. It’s easy, cost-efficient, and effective.
Mrs. Samurai gives you a quick run-down on how to get the tech documents you need in the Downloads section here at Appliantology. Find out how you, too, can quickly and easily build your own custom library of tech documents on a Kindle Fire, iPad, or other tablet in 4 easy steps!
1 Comment
