applianceman97's Blog
    18
    45
    53,988
"New style" electrolux drain pump
applianceman97
Ran into this frigidaire/electrolux drain pump today. Had not replaced this one before. I had the usual front load pump in stock. After looking at the new style and the old style motor i found that they used the same drain motor just a different housing and mounting base. I ended up removing the motor from the old style pump and mounting it to the new style housing and mounting base. This pump is mounted sideways right in the front of the unit. After changing out the motor it worked like a Charm.
Just wanted to share in case not all of you had seen this newer style pump. Looks like they have 2 different ones like this. Here is what it looks like.
Part number: AP4510671
  • Like 4
2 Comments
Great info man.  Didn't know they changed it.  It's good to know we can still use the motor from the other pump.  Thanks.
Link to comment
Great post! Mucho domos for the heads up in this, mah bruvah!
Link to comment
