From: Amana NED7200TW Dryer no heat, problem with cycling thermostat?
Posted by kdog, 16 March 2012 · 1,182 views
[Yes, I did reset the breaker and checked the voltages.  Here's the wiring diagram:
Source: Amana NED7200TW Dryer no heat, problem with cycling thermostat?
Stupid question: what did the element ohm at? It should ohm around 11 ohms of resistance at room temperature.
My amana dryer is about 13 years old and now the very last appliance in my house to break. I literaly fixed my front loader washer by following instructions on this site. Had to replace the pump. When my husband came home he could not believe it. Did say he was really proud of me.
Dryer has quit heating at all. So far we have not done or checked anything. So I am ready to start learning. Thank you
I know this is a dated post, but I've had dryers like this one. What voltage are you get on the two posts of the the heat relay on the board? Does the cycling thermostat ohm open or closed?
May 2013
M T W T F S S
  12345
6789101112
131415161718 19
20212223242526
2728293031
