  • entries
    862
  • comments
    1,398
  • views
    2,717,937
Ultimate Appliance Gift Ideas
<p>The Samurai has scoured both the Innernet AND the Outernet rounding up those perfect Christmas, Hanukah, Kwanzaa, and Festivus gift ideas for that special Fixer Dude or Dudette in your life.  <strong>Click the photos</strong> for more info or to purchase.</p>
<p> </p>
<p>Stay warm AND safe with this Pocket Air Check combustible gas leak detector. Works with Natural and LP gas.</p>
<p><a href="http://www.repairclinic.com/PartDetail/Gas-Leak-Detector/500A0300A/1028649"><img src="http://www.RCappliancepartsimages.com/dbImages/i/00002404/Gas-Leak-Detector-500A0300A-00723789.jpg"></a></p>
<p> </p>
<p>Multimeter.  The indispensable tool for every DIYer.  Specs: Volts AC 750 , Volts DC 1000, Amps AC 10, Resistance max. (Ohms) 2M, Continuity, Temperature -4 °F to 2498° F, Display (Counts) 2,000, Operating Temperature 32° F to 74° F (0°C to 23°C), Fuse Protection mA: 0.2A/ 250V, Power 9 V Battery (included), Size 5.5"L x 3"W x 1.5". Temp probe included.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #005789; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Multimeter/DM10T/964740"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00003749/Multimeter-DM10T-01128791.jpg" alt="Multimeter - Part # 964740 Mfg Part # DM10T" /></a></p>
<p> </p>
<p>Non-contact A/C voltage detector. Test for voltage without touching any bare wires. This detector works by sensing voltage through the wire's insulation. Detector has an audible beeper and visible flashing light indicator.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Voltage-Tester/1000100009/1255942"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00003458/Voltage-Tester-1000100009-01040462.jpg" alt="Voltage Tester - Part # 1255942 Mfg Part # 1000100009" /></a></p>
<p> </p>
<p>3 in 1 tool for splicing wires. Has wire strippers for stripping off insulation from the wire. Crimpers for crimping solderless connectors and bolt cutters for cutting small bolts. High quality.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Wire-Splicing-Tool/1002/967613"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00001858/Wire-Splicing-Tool-1002-00559806.jpg" alt="Wire Splicing Tool - Part # 967613 Mfg Part # 1002" /></a></p>
<p> </p>
<p>240 Volt 240 Volt outlet checkers for checking the outlets on electric ranges and dryers.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #005789; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Tool/4396932/1176379"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00004195/Tool-4396932-01262685.jpg" alt="Tool - Part # 1176379 Mfg Part # 4396932" /></a></p>
<p> </p>
<p>Dryer Vent Tester for testing the backpressure on a dryer vent.  Excessive backpressure is the single most common cause of overly long dryer times, repeatedly blowing thermal fuses and poor dryer performance.  A vent can be free of lint and still be bad!  Use this spiffy tool to check your dryer vent.  A must-have if you're a pro in the trade.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Tool/W10106710/1447456"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00003919/Tool-W10106710-01179855.jpg" alt="Tool - Part # 1447456 Mfg Part # W10106710" /></a></p>
<p> </p>
<p>Microwave leakage detector.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Microwave-Test-Kit/A138/1668485"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00003008/Microwave-Test-Kit-A138-00904810.jpg" alt="Microwave Test Kit - Part # 1668485 Mfg Part # A138" /></a></p>
<p> </p>
<p>Refrigerator and freezer thermometer, temps from -20 to 80 degrees Fahrenheit. Thermometer face has special markings to show where food is safe and where it is at risk of spoilage.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px;" href="http://www.repairclinic.com/PartDetail/Thermometer/8171720/903650"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00002866/Thermometer-8171720-00862135.jpg" alt="Thermometer - Part # 903650 Mfg Part # 8171720" /></a></p>
<p> </p>
<p>The Kill-A-Watt Energy Usage Meter. This plug-in meter allows you to track total power consumption by hour, day, week, month, or year. Also displays Voltage (V), Line Frequency (Hz), and Power Factor (PF). 15 amp maximum. No batteries required. Accepts standard 110 volt plugs, 2 or 3 prong.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px;" href="http://www.repairclinic.com/PartDetail/Energy-Usage-Meter/P4400/1012487"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00003919/Energy-Usage-Meter-P4400-01179804.jpg" alt="Energy Usage Meter - Part # 1012487 Mfg Part # P4400" /></a></p>
<p> </p>
<p>Freezer alarm, sounds if freezer temperature goes above 15 degrees.  Never lose expensive frozen foods again!</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px;" href="http://www.repairclinic.com/PartDetail/Freezer-Alarm/8171458/786349"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00003205/Freezer-Alarm-8171458-00964574.jpg" alt="Freezer Alarm - Part # 786349 Mfg Part # 8171458" /></a></p>
<p> </p>
<p>Gasohol tester.  Used to test the alcohol content in the fuel.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px;" href="http://www.repairclinic.com/PartDetail/Gasohol-Tester/795161/1611245"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00004112/Gasohol-Tester-795161-01237600.jpg" alt="Gasohol Tester - Part # 1611245 Mfg Part # 795161" /></a></p>
<p> </p>
<p>Polder 3 function thermometer: large LCD read out displays the temperature of food during cooking. Presettable HI/LOW and inside the range temperature alert. Timer: 24 hour count down and count-up. Clock: Real-time clock. Stainless steel probe. Temperature chart and battery included.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #005789; padding: 0px; margin: 0px;" href="http://www.repairclinic.com/PartDetail/Digital-Meat-Thermometer/60190/905158"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00002282/Digital-Meat-Thermometer-601-90-00687219.jpg" alt="Digital Meat Thermometer - Part # 905158 Mfg Part # 601-90" /></a></p>
<p> </p>
<p>Glide n Guard floor protector for appliance moving.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px;" href="http://www.repairclinic.com/PartDetail/Floor-Protectors-for-Moving-Appliance/93001/12914"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00002092/Floor-Protectors-for-Moving-Appliance-93001-00629950.jpg" alt="Floor Protectors for Moving Appliance - Part # 12914 Mfg Part # 93001" /></a></p>
<p> </p>
<p>Affresh HE Washer Cleaner Pack - Use once a month to keep your HE (high efficiency) washer clean and odor-free! 3 Power Puck tablets and 4 Grit Grabber cloths per box.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #005789; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Cleaner-Kit/W10306172/1914804"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00004042/Cleaner-Kit-W10306172-01216796.jpg" alt="Cleaner Kit - Part # 1914804 Mfg Part # W10306172" /></a></p>
<p> </p>
<p>Affresh Dishwasher and Disposal Cleaner - 6 Tablets.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Dishwasher-and-Disposer-Cleaner/W10282479/1552531"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00003638/Dishwasher-and-Disposer-Cleaner-W10282479-01094374.jpg" alt="Dishwasher and Disposer Cleaner - Part # 1552531 Mfg Part # W10282479" /></a></p>
<p> </p>
<p>Glisten dishwasher cleaner</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Dishwasher-Cleaner/5304482929/1915432"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00004152/Dishwasher-Cleaner-5304482929-01249713.jpg" alt="Dishwasher Cleaner - Part # 1915432 Mfg Part # 5304482929" /></a></p>
<p> </p>
<p>Refrigerator and freezer condenser coil cleaning brush with instructions. Also works great for dryer lint.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Long-Handled-Bristle-Brush/5303318693/12859"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00003925/Long-Handled-Bristle-Brush-5303318693-01181494.jpg" alt="Long Handled Bristle Brush - Part # 12859 Mfg Part # 5303318693" /></a></p>
<p> </p>
<p>Solid-surface range element cleaner (Sponge no longer included).</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Solid-Surface-Element-Cleaner/5303310267/12830"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00003086/Solid-Surface-Element-Cleaner-5303310267-00928798.jpg" alt="Solid Surface Element Cleaner - Part # 12830 Mfg Part # 5303310267" /></a></p>
<p> </p>
<p>Vacuum cleaner attachment for condenser and dryer cleaning - This long vacuum cleaner attachment will help to clean dust and lint build-up in and around your refrigerator condenser coils underneath the refrigerator and dryer lint in the area where the lint filter is inserted. Fits 1-1/4 inch vacuum hose.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Vacuum-Hose-Attachment/8171579A/1544893"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00003044/Vacuum-Hose-Attachment-8171579A-00915732.jpg" alt="Vacuum Hose Attachment - Part # 1544893 Mfg Part # 8171579A" /></a></p>
<p> </p>
<p>Dryer vent cleaning brush. For 4" diameter round ducts. 20 feet long.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/20-Foot-Vent-Cleaning-Brush/18001034/424663"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00001858/20-Foot-Vent-Cleaning-Brush-18001034-00559870.jpg" alt="20 Foot Vent Cleaning Brush - Part # 424663 Mfg Part # 18001034" /></a></p>
<p> </p>
<p>Complete Ceramic Cooktop Care Kit - contains a 10 ounce Cooktop Cleaner to clean and polish all glass or ceramic cooktops. A 4 ounce bottle of Cooktop Protectant. Six small cooktop cleaning pads and one larger Cooktop Protectant applicator.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Glass-Cooktop-Cleaner/31605/959474"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00002401/Glass-Cooktop-Cleaner-31605-00722928.jpg" alt="Glass Cooktop Cleaner - Part # 959474 Mfg Part # 31605" /></a></p>
<p> </p>
<p>Stainless steel cleaner.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Stainless-Steel-Cleaner/31462A/1542817"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00004188/Stainless-Steel-Cleaner-31462A-01260510.jpg" alt="Stainless Steel Cleaner - Part # 1542817 Mfg Part # 31462A" /></a></p>
<p> </p>
<p>Gas grate cleaner.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #000000; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Grate-Cleaner/316119700/496592"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00002120/Grate-Cleaner-316119700-00638424.jpg" alt="Grate Cleaner - Part # 496592 Mfg Part # 316119700" /></a></p>
<p> </p>
<p>Rust remover - Removes rust stains from clothes, dishes, glassware, kitchen and bathroom fixtures, painted surfaces, concrete and water softeners. 16-ounce bottle.</p>
<p><a style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; text-decoration: underline; color: #005789; padding: 0px; margin: 0px; border: 0px initial initial;" href="http://www.repairclinic.com/PartDetail/Rust-Remover/W10278629/1550725"><img class="productImageDimensions" style="font-weight: inherit; font-style: inherit; font-size: 11px; font-family: inherit; width: 175px; padding: 0px; margin: 9px; border: 0px initial initial;" src="http://www.RCappliancepartsimages.com/dbImages/i/00002864/Rust-Remover-W10278629-00861715.jpg" alt="Rust Remover - Part # 1550725 Mfg Part # W10278629" /></a></p>
<p> </p>
7 Comments
There's also a real cool universal touchpad tester That I use often on dishwashers . You may want to consider adding it to this awesome list of goodies.     Part # TT2000-AP
You forgot html tags for the images to show up.
<html><body> (at the very beginning)
</body></html> (at the very end)
