  1. Original File Size 4490212
  2. Mime Type image/jpeg
  3. Image Height 2304
  4. Image Width 3072
  5. Color TRUE
  6. Byte Order Motorola FALSE
  7. CCD Width 5mm
  8. Aperture f/7.1
  9. Camera Make Canon
  10. Camera Model Canon PowerShot SD800 IS
  11. Orientation The 0th row is at the visual top of the image, and the 0th column is the visual left-hand side
  12. X-Resolution 180/1
  13. Y-Resolution 180/1
  14. Resolution Unit 2
  15. Last Modified 2012:11:14 15:02:41
  16. YCbCr Positioning centered
  17. Exposure Time 1/320
  18. F Number 71/10
  19. Exif Version 0220
  20. Date Taken 2012:11:14 15:02:41
  21. Date Digitized 2012:11:14 15:02:41
  22. Compressed bits/pixel 5/1
  23. Shutter Speed 266/32
  24. Aperture Value 181/32
  25. Exposure Bias Value 0/3
  26. Max Aperture Value 95/32
  27. Metering Mode CenterWeightedAverage
  28. Flash 16
  29. Focal Length 4600/1000
  30. Flashpix Version Flashpix Format Version 1.0
  31. Color Space sRGB
  32. Image Width 3072
  33. Image Length 2304
  34. Interoperability Offset 3314
  35. Focal Plane X-Resolution 3072000/225
  36. Focal Plane Y-Resolution 2304000/169
  37. Focal Plane Resolution Unit 2
  38. Sensing Method One-chip color area sensor
  39. Exposure Mode Auto exposure
  40. White Balance Manual white balance
  41. Digital Zoom Ratio 3072/3072
  42. Scene Capture Type Standard
  43. Inter-operability Index R98
  44. Inter-operability Version 0100
  45. Camera (Maker Note) IMG:PowerShot SD800 IS JPEG
  46. Firmware Version Firmware Version 1.00
