ge ice dispenser
  • This topic is locked This topic is locked
25 replies to this topic
#21 Guest_cojenny_*
Guest_cojenny_*
  • Lurking at the Threshold
Posted 12 September 2005 - 12:50 PM
It is a GE fridge - that other thread is very helpful.  Thanks!!!
#22 Guest_sktn77a_*
Guest_sktn77a_*
Posted 21 September 2005 - 06:19 AM
Just had the Sears repairman replace our GE auger motor - $300!!!   (The motor costs $100).
I wish I'd seen this thread first.  I'll try thawing/drying out the old motor and then testing it as suggested.
Keith
#23 Guest_Beavus_*
Guest_Beavus_*
Posted 21 September 2005 - 03:42 PM
I wonder what would happen if you removed the auger motor and blow dried it real good and then stuck the motor in quart plastic zip lock bag and poked the shaft and terminal connectors thru the bag and maybe even wrap a little electrical tape around the whole thing and reinstall it?
#24 mopar X
mopar X
    Yamabushi
  • Master Appliantologist
  • 76 posts
Posted 21 September 2005 - 05:00 PM
If you encounter a frozen auger motor on a side-by-side new energy model refrigerator, we now have a solution. To resolve this condition, order the auger motor shield WR17X11111.
Install the shield to redirect airflow and prevent the auger motor from freezing. This modification applies only to models manufactured beginning in 2001.
Materials Required:
ı WR17X11111 Auger Motor Shield
ı Electrical tape
Follow these steps to install this shield:
A. Remove the auger motor from the cover
and motor assembly.
B. Before assembling the shield, make sure
the locking tabs on the shield are bent
inwards about 20 degrees.
C. Slide the shield onto the motor from the
side opposite the terminals.
D. Slide it forward completely and drop it
down into place and assure:
1) The top of the shield locks directly
behind the wire coil.
2) Locking tabs are locked under the motor
stack.
3) The air-gaps between the sides and the
top of the shield are at a minimum.
E. Secure the shield by firmly wrapping
electrical tape around the auger motor
and shield (at least 1 complete
revolution).
F. Also use piece of tape to cover gap
between motor stack and gearbox.
G. Re-install the auger motor into the cover
and motor assembly and replace in the
refrigerator.
#25 Samurai Appliance Repair Man
  • 24,207 posts
Posted 21 September 2005 - 05:20 PM
Great, thanks for posting that, Mopar!
Good to see you around again.:dude:
#26 Guest_poundridger_*
Guest_poundridger_*
Posted 02 April 2006 - 03:55 PM
[user=0]harkenco[/user] wrote:
tfx25jr is the model of the f/f. When you push on the ice dispenser button you can hear a buzzing and sometimes get 1 or 2 ice cubes to drop into the chute. They do not drop thru the flap though.
I have a GE TFX25JR too with an ice machine that does not make ice. It does make chilled water and it the auger works. When I search for TFX25 JR I am told that is not a model #
