Sign in to follow this
Followers 0
Guest holidaymw
Kenmore Dryer IS TOO SLOW
2 posts in this topic
My Dryer IS TOO SLOW... Can I run a cycle without the vent hose to determine if the vent is blocked?
Yes, that is a good way to determine if the venting is your problem or not.
If you dryer works ok with vent disconnected, be sure to fix the problem (clean the vent out) and reattach vent hose. Don't run without the vent attached for any longer then just for testing purposes. You don't want all the moisture from the dryer in the house.
William Burk (Willie)
Eureka, CA 95501
Followers 0
