  • Announcements
rennies7
Kenmore washer cuts off!
11 posts in this topic
My Kenmore washer is about 10 yrs. old. model #110 Serial Number 92582220 ( hope I followed the rules.)
Here's the deal. It will fill up agitate for about 2 minutes and then cut off. Wait a few minutes then it will come back on then cut off again. There is a "electrical" smell. It will continue doing this through the rinse and spin cycle also.
My husband replaced the coupler? (the rubber thingy that makes it agitate) and today the entire motor. I am about to throw this stupid machine in the street. Please help if you can. My husband has steam coming out of his ears.
Thanks !!!
seems that you have excessive current draw on the motor,does the pump and transmission shaft turn freely??
Yes what kdog says is the deal. Since you have had the pump already off , leave it off. You can leave the hoses hooked up to it and tie it off to the left with a coat hanger. Then jump the lid switch so the machine will work and see if the units motor will work.
If so the pump is binding up. You can also turn the pum with a large flat blade screw driver and make sure that it spins freely.
With the motor off and on the floor you could do two things. You could take a wrench to the transmission shaft and turn it. It should be firm but turn.
With the motor on the floor and wired up you could also hold it in place and turn on the machine which will start the motor and see if it works okay by itself. When you do this be prepared to hold the motor tight. I use my shoes with rubber sole and a foot, cause it will jerk when you first start it so don't be dazzeled.
You just want to narrow this down to which thing out of the three is binding up. The pum, the motor itself, or the transmisssion.
Good Luck.
If your model has a speed contol switch, replace it 1st.
Nick
Like Nick says, I also would be looking at the speed selector switch. You do have one on this machine, (called "Cycle Selector" 4 postion speed control switch.
I've seen it a few times where the points will weld together in the switch which will be sending electricity to both Hi and Low speed motor windings at the same time which will make the motor run real loud and then overheat and kickoff on the thermal overload like yours is doing.
When the machine is running for that 2 minutes before it shuts off does it seem to be much louder than normal?
As soon as the machine starts to agitate turn the speed selector switch to a different setting and see if the loudness goes away and machine keeps running. If this works you will need to replace the "Cycle Selector/Speed control switch".
Here's the part if you determine that is what you need: CLICK HERE
On the subject of the speed switch, that's definitely a possibility. An issue I used to run into was people changing speed while the machine was running. This will very quickly burn up the contacts in the switch. If you realise you've selected the wrong speed, stop the machine then change speed and restart.
PTL the unit is fixed.  After a new coupler, new motor, new timer and then finally a new speed switch, the problem is fixed.  I wish I had been on here prior to the new coupler and new motor.  I received the new timer for free....so all said, $180 for the repair.  The switch ($25) was the problem.  Thanks to all who assisted with this dillema.  Once again, I Am The Man at home.....thanks to all who helped.
Daddy is going to get rewarded....:)
Nick,
Thank you so much, I wish I'd seen your suggestion a week prior to my battle.  I appreciate your help.
Stuart
Willie,
Thanks for the help, you hit the nail on the head.
Stuart
Mac,
Thanks, your ideas were right on the money, you hit the nail on the head.
Stuart
Kdog, GLC:
Thanks for the input.  All the advice was sound and appreciated.  The washing is working.
