bridgejr
Frigidaires are not idiot proof.
7 posts in this topic
We just got a new Frigidaire today (new model FRT8B5EW2), and we didn't have it in the house for 10 minutes before doing something stupid to it.  We were taking out the packing material. There was some styrofoam inside the part of the frige that's behind the light bulb on the ceiling of the frige compartment. We dug it out, and then could see that there was more inaccessible styrofoam leading up to the freezer compartment. Then we noticed there is a part number on the styrofoam we dug out: 240362601.  When we googled it we found that number corresponds to the bottom of the air diffuser. So, basically we just destroyed a brand new part in a brand new appliance.  I have ordered a replacement part, which should arrive in a few days.  In the meantime, we have been swearing a lot and asking ourselves these questions: what effect(s) will this have on the operation of the appliance?  What can we do to mitigate these effect(s) until the replacement part comes?  And, is there any special information we need to know when replacing the part?  Please remember that we are not very bright (as illustrated by our willful destruction of a brand new part in a brand new appliance), so please give detailed instructions.  Thanks, Samurai.
when it is installed in the proper place,the peice you destroyed forms a part of the air duct which directs freezer tem. air toward the unit cold control. without this part the following things will happen: control will not have air directed towards it,thereby overrunning and likely freezing things in the fresh food compartment,even with the unit shut off,the opening that is there in the ducts absence will allow freezer air to "migrate" by natural convection,  can vou just tape the duct together and secure it in its proper place somehow until your replacement arrives??
Yeah, I've tried to tape together the bits that are left--there is mostly one large chunk, and then the sides were all crumbled.  Now that I understand what the thing is supposed to be doing (thanks!), I will try to position the damaged pieces so they direct the air toward the control.
Does the replacement part require any adhesive, or do we just stick it into the space we dug its predecessor out of?
there are channels moulded into it,so when you push the peice into position,it is a friction fit.just don't force it cause as you've already seen,they break quite easily.
This is a new fridge which should be under warrantry. Call for service and it could be replaced for free.
I don't believe the warranty covers what we did to it, because it's not a defect in workmanship or material.  Their customer service line is closed on the weekends.  I want to call them and ask if we can have a diagram of the air diffuser so we know how to put in the replacement parts, but I don't know if they will send that or not.
Here's a picture of how the parts are put together: CLICK HERE
Here's where to order the part you destroyed: Part ref#13--240362601 CLICK HERE
Did you do any damage to the other part ref#12?
Four screws, ref#81, hold the control consule up in place. Unplug unit, remove the four screws and consule should drop down for easily replacing any of the parts in it.
