  • Announcements
Mikeo
Kenmore Front Loader - Won't Pump
5 posts in this topic
My Kenmore front loading model #417.41042000 agitates and advances through the cyles, but will not pump water out. When the washer is advancing through cycles and comes to the point when water should be pumped out, there is simply a buzzing sound. I removed the pump to be sure there wasn't anything binding on it...there wasn't anything in the pump and the impellors spun freely, although the pump was very hot.
Is this pump bad? Any other things to trouble shoot? My wife returns tomorrow and if I can't fix it by then, I'll be washing my clothes at the laundrymat. :(
Thanks.
Sounds like you have a bad pump but the only way to know for sure is to use a meter and check that the pump is getting 110-120volts when you hear it humming. If the pump is getting the volts required and just humming and obviously isn't jammed then time to replace pump.
Or use a test cord and plug the pump in just using a test cord to see if it works if you don't have a meter.
Here's the pump if that's what is needed: CLICK HERE
If I recall, the 417 has a coin trap just before water enters the pump. It's moulded into the black rubber hose coming from tub. I have found nails, coins, paper clips, rubber backing from throw rugs, you name it. Any of which will slow/stop water flow. One thing I do on these types of issues is place it in a drain cycle and check to see how well the water is flowing from drain line. [shadow=green]Sincerly, BrokenArrow[/shadow]
Thanks for that information. I inspected the black rubber boot that connects to the pump for foreign debris and having found none, ordered a new pump. I'll re-check the boot and verify that water will flow in the drain cycle.
I appreciate the leads and will post the results.
The problem was the pump. The washer is running good as new now. Thanks to Budget Appliance and Broken Arrow for their help.
