Kenmore Dishwasher 16884000
3 replies to this topic
#1 Jimbro
Jimbro
  • 2 posts
Posted 12 June 2005 - 08:00 PM
I've lost the manual.  The airdry light flashes. I can open the door and the led stops.. close the door it starts flashing again. I can hit cancel and the quickrinse light flashes with the airdry light. open the door closeit and one or the other flashes... hit cancel and both flash....
help.
#2 Jimbro
Jimbro
  • 2 posts
Posted 12 June 2005 - 08:16 PM
found this when i googled my model:
July 30 2003 source 665 GIANT TUB KENMORE[/b] DISHWASHERS STOPS IN MID.CYCLE Dishwasher will stop in mid-cycle and will not advance , customer cannot restart dishwasher. Due to temperature rise in console during Sani Rinse , the TCO will open and cut power to the electronic control. lnstall Therm Cutoff Kit , Part Number 8193762. This kit includes a new T.C.O., plastic shield , harness assembly ( includes thermal block ) , mini zip ties , and detailed instruction on proper installation. KENMORE[/b] Model Numbers: Affected serial numbers: FK30 through FM47 15872000 15874000 15879000 15882000 15884000 15889000 15892100 15894100 15899100 15912001 15914001 15919001 15922001 15923001 15924001 15929001 15932000 15933000 15934000 15937000 15939000 15952000 15953000 15954000 15959000 16512200 16514200 16519200 16532200 16533200 16534200 16539200 16572200 16574200 16579200 16582200 16583200 16584200 16589200 16592200 16593200 16594200 16599200 16872000 16874000 16879000 16882000 16884000[/b] 16889000 16912001 16914001 16919001 16932000 16933000 16934000 16939000 16952000 16953000 16954000 16959000 16972200 16973200 16974200 16979200 17512200 17514200 17519200 17532200 17533200 17534200 17539200 17572200 17574200 17579200 17582200 17583200 17584200 17589200 17592200 17594200 17594200 17599200
Wife cant remember if it was midcycle when it quit. You think thats it?
Jimbro
#3 kdog
    RoughShod
  • 7,428 posts
Posted 13 June 2005 - 03:40 AM
thermal cutoff will cut power supply to control,if you still have flashing lights,i doubt the t.c.o.,there is an issue with the heating element that causes the machine to shut down and the lights to flash. it is also possible your machines control has become locked in some mode(child lok,diagnostic,etc.),cut off the power to the unit,fetch the tech sheet from the kickpanel and have you a good read. after a period of time,restoring power may reset it,otherwise,examine techsheet for more detailed info.
#4 Pegi
Pegi
  • 13,120 posts
Posted 13 June 2005 - 08:39 AM
Since this has the Kenmore name on it we cannot pull up any information, however since this is made by Whirlpool, this possibly could apply to your unit, but we have no way of knowing.
[align=left]DISHWASHERS WITH ELECTRONIC[/align]
[align=left]CONTROL[/align]
[align=left]Models: KUD01, DU640XT, DUL300XT, GU1100XT, GU1200XT, GU1500XT, GU2300XT[/align]
[align=left]Serial Code Range: FK28 – FM04[/align]
[align=left]STOPS IN MID-CYCLE, INDICATOR LIGHTS BLINKING[/align]
[align=left]Dishwasher will stop in mid-cycle and will not advance.[/align]
[align=left]One or more of the cycle, option and status indicator lights[/align]
[align=left]will blink.[/align]
[align=left]K8178151[/align]
[align=left]January 2002
[/align]
[align=left]CONDITION:[/align]
[align=left]CAUSE:[/align]
[align=left]RESOLUTION:[/align]
[align=left]The electronic control is reacting to higher than normal[/align]
[align=left]line voltage, (over 125 volts), and higher than normal line[/align]
[align=left]signal distortion that exists in some parts of the country.[/align]
[align=left]A revised electronic control, part #8530909, is available[/align]
[align=left]to better handle high voltage conditions. The current stock[/align]
[align=left]of replacement electronic controls has been reworked, to[/align]
[align=left]supplement production controls being produced. Modified[/align]
[align=left]controls will have a label, “REWORKED HI-LINE” to[/align]
[align=left]identify them as reworked controls and are approved as[/align]
[align=left]service replacements.[/align]
[align=left]NOTE:
If the line voltage is normal and a single Cycle,[/align]
[align=left]Option or Rinse Only light is blinking, the cause is usually[/align]
[align=left]a stuck or shorted keypad on the active overlay, not the[/align]
[align=left]control. A resistance check of the active overlay should[/align]
[align=left]always be made, using the keypad matrix in the product[/align]
[align=left]tech sheet, prior to replacing the electronic control.[/align]
