bethlehem
Maytag Washer LAT8604 won't spin
3 posts in this topic
Our Maytag LAT8604AAE will not finish its spin cycle with a full tub of water.  I had a similar problem one month ago and the problem at that time was the lid switch.  I the witch back to the parts store and they tested the switches and the fuse on the lid switch assemplby board and the recently purcahsed part is showing good.   I tried to manually spin the agitator but could only move it an inch or so in either direction.   If the lid switch tests out OK what then could the issue possibly be?  A motor or transmission?  The machine is about 11 years old and our family puts it to heavy use.  As simple observation, the lid switch went bad with aa heavy load of bedding and sheets.  this time it failed with sheets and beach towels from a day at the pool.  Could the heavy load be causing this issue?  Any ideas would be greatly appreciated.
OK, I played with the lid switch for the 3rd time after reading about the proper way to place it in the washer.  I tightened it in place after lifting the washer lid 3 inches and waiting to hear the click of the micro-switch on the lid assembly board.  It is now spinning as I type this.  I must have not installed the lids switch properly when I replaced it a month ago.  It all seems to be working properly again.
THAT WAS EASY!!!:party:
