tbone
Washing machine
4 posts in this topic
Hi...I"m trying to take the panels off of my washing machine b/c I have a leak. It is a Sears Kenmore...about 14 years old. The front and side panels are all one piece. How is the quickest way to take it off? Thanks!
This will show you how to remove the case...  Then you will be able to un-clip your dripping pump and replace it.  If it has not leaked for some time and stuck on the motor shaft, that is.  Pegi
Hi there,
You were of great help and I just got the part in that I needed. my problem now is that after getting everything assembled, I don't know where to plug the lid switch terminal back into so I can flip the console back down. I'm looking all over for somewhere that  a 3 hole plug should insert but can't find one anywhere. Am I blind? HELP!!
It comes thru the rear of the case under the console, usually nearer to the right side of the case, will be white plastic just like the plug-in on the lid switch
