baltimore_kenmore_victim
Hell hath no fury as a washer that stays in the wash cycle all day
6 posts in this topic
I have a Kenmore 110 Toploading washer that will not complete a wash cycle.  The tub fills up with water and then the cycle starts but stays in the same place.  Is this a timer problem????
Additionally, I have a mysterious leak that I am sure is not the tub, but not sure how or where else to check....
110 just tells us this is a Whirlpool built washer, would need the rest of the model number to see what is in this washer.  Is it a direct drive or belt driven??? If the timer does not advance you probably have a dead timer motor but would have to replace the whole timer.  To address the water leak will need more information on what style it is by seeing the model number.
Pegi,
Thanks for the reply- my model number is 82692120.  This is belt driven model.
Aaaaa, so this will take more sluthing.  Best to remove the rear access panel and run the washer while seeing where the leak is coming from with a flashlight without getting sucked into the washer and becoming part of the guts by the belt...could be a hole in the tub, tub grommet, spin tube seals, pump, sump grommet, hole in a hose, endless possibilities here on these old belt driven washers.  All leaks are visable, just have to see where it is coming from.
Will give it a look and let you know the results.  Thanks a bunch for the help!
