n6e6i6l
Stacked Whirlpool washer and dryer, both with issues!
4 posts in this topic
Whirlpool "Heavy Duty Spin Twin", Model# YLTE5243DQ0.
So we have just moved and inherited this laundry center with problems.
1. The dry no longer produces any heat, everything else seems to work just fine.
2. The washing machine goes a little crazy during the agitation. It seems like it’s a very unbalanced load, but that is definitely not the case. No matter how little and balanced of a load put in, the drum seems to bash around making a ton of noise.
Help please!
Thanks in advance.
Dropping the Y brings this up in the USA.  The dryer could be the heating element, thermostat, etc for no heat.  The washer could be one of the supports has gone bad, glides , balance spring has broken or come loose, etc..  Will almost have to do a tear-down on these to see where the problems are in this unit
Hmmm, ok.
If I where to start taking it apart myself and see if anything is obviously broken, am I realistically going to find anything seeing as I don't really know what I'm looking at?
wpdry107.jpg?dc=4675399380722103158Although yours is a stacker, the disassembly help here for the Whirlpool old-style dryer should get your started.
Basic dryer diagnostic information here:
http://fixitnow.com/2004/08/online-dryer-diagnostic-guide.htm
Help on making basic electrical measurements here:
http://fixitnow.com/2004/12/appliance-repair-revelation-making.htm
Thermal fuse, hi limit, and thermostat are all on back, roughly (but not exactly) corresponding to this picture:
