  • Announcements
dgibsonvt
Viking VGSC305-4BDWH Range
8 posts in this topic
Assuming my earlier post failed and your're not boycotting Viking inquiries, I once again solicit your higher wisdom on getting to my oven's inner reality. I need to replace the igniters and burner tubes but can't get the oven door to release from the hinges. I'd appreciate any tips on removing that impediment and on changing over the burners, ie, how far do I tear things down to reach and exchange the burners (will it be like the layers of an onion?), and are there complcations I should know about (beyond the obvious ones of just owning this brand)?
Not at all! Musta been a forum glitch because even your post count is showing 1 post (at the time of this reply). The Samurai does not discriminate based on brand. I even tolerate GE appliances.
The attachment will help you with oven door removal. Ignitors and burners coming in followup replies.
viking-range-door-removal.pdf
Thank you Samuri - I will try to refine my technique with inscrutable oven door. Original attempt was according to owner's manual instructions which are less complete than your attachment. I'm going out now to puchase the burner tubes, an act of true commitment (which I hope will not turn into an act of true desperation).
Piece of pie, tovarish! This is simple stuff, three glugs shy of two mugs on the world-famous SUDS-o-meter.
Konishuwa,
I have found the answer but it is not there! I need to remove the oven door from my older VGSC305-4 VIKING stove and found a PDF "viking-range-door-removal" you posted here -- got excited however the viking range door removal PDF is actually "burner replacement"..... If you still have the correct PDF could you post onegaishimasu
Arigatou gozaimasu
DOOR REMOVAL VGSC306-366-486.pdf
link PM'd
