montmurf
Leaking suction line from evaporator. Frigidaire Fridge
10 posts in this topic
My technician says my leak is internal and is in the suction line from the evaporator. The line is not accessible from the back of the fridge nor can I get to it from inside the compartment. Said technician wants to cut holes in the back (ouside) surface to extract the line. I'm not sure about this. The guy wasen't too inspiring as to his competence for this scope of job.
My fridge is a "Frigidaire Gallery Series, 18 cubic foot, top freezer, fan cooled condenser" Model GLRT 184 RA. Has anybody done this job before or had this suction line replaced on their fridge?
if the suction line is foamed into the cabinet,it is not accessible- how would you find a leak there??  sounds like you should seek a second opinion- has it indeed leaked,or has the cap tube become restricted,symtoms are very similar in both instances- how exactly did this person check for leak-did he/she access the sealed system??
What you want to be absolutely sure about here is whether or not you really have a sealed system problem.  If you do, and the refrigerator is NOT under warranty, then the precise location of the leak is academic because you're better off going shopping for a new one.
I'm assuming that he concluded that it's an internal leak from the fact that there was no oil traces to be found anywhere on the external components. He guaged the the compressor and found only residual pressure. He didn't tell me how much, but told me that there was basically very little coolant left in the system.
He recharged the refrigerant and told me the fridge will run well for about 2 weeks before it dies a 2nd slow death. Is this a common problem? Maybe the fridge model is known to be a lemon? The fridge is only 3 years old but not warrentied because we're the second owners and the original purchaser didn't send his product registration card nor did he give us any paperwork or store receipt. It's a beautiful fridge (when it's working).
Seems like it would be under warranty from the manufacture date then.  Ask if it is under warranty by the serial number.  If it is not under warranty or they will not honor it because you are the second owner, you need to go shopping for a new Whrilpool frig.
If you have a leak and it's proven that it is the heatexchanger of which i doubt,there is a heatexchanger kit (external) available.
if it is an evaporator leak , the evaporator is replaceable and relatively cheap!
don't guess if you have to, isolate high and low side..
good luck!!
Peggi: I did notice in one of your post you were done with the flu ,hope all now is ok .
you also mention you are getting tired of helping people, well i have been around 36 yrs in the service business and can tell you two things, one - once you have been bitten you will always help, two---- i have been watching your comments on this site and one other site.without people such as yourself and the Samurai as well as many others no problems would be solved ,it would then just become a large appliance garbage dump!!!
 Please keep up the good advice !!!
We will all thank you in the end!:D
Thank you Dr. Freeze for the kind words.  I like helping people and will continue to do so.  However I get tired of wasting my time with people who are too dense to listen and follow our advise. I will just ignore those posts and go on to someone else who appreciates our efforts., to keep them all from the appliance garbage dump from Hell.  :P  Your friend, Pegi
Well I sure as hell appreciate these posts. They're very insightful as to how not to get "screwed".
I got the estimate today... new evaporator $166, new suction line $41, labor 11/2 hours including recharging coolant $140. Is this all legit? Keep in mind these are in Canadian funds. They're going to drill a small hole,  1/2" approx and run a new suction line externally down the backside, leaving the original one in place. The evaporator can be changed through the freezer compartment.   The advice of the repair guys is to do the fix since it's the first occurance of a problem and the fridge is very young. For debate purposes, the guarantee is a non starter because of the missing paperwork. It will be pay now and try to claim after the fact directly with "Frigidaire Inc"
Any opinions??? Thanks
Buy a new frig. with a brand new warranty and be sure it is s Whirlpool Brand.   Simpler is better.  The Frigidaire's have known problems as well as Maytags and G.E.'s
