  • Announcements
dartcc
Frigidaire freezer door
2 posts in this topic
I have a model plhs269zdb0 and need to replace the poly 5/16 line in the door, how do i remove the inside panel to replace it?
thanks
justin
from what i recall,it is best to access this from the front by first removing the dispenser housing and switches. you can then disconnect the line,tape a string to the tubing at the bottom to pull up through with the old tube,as you can then attach it to the new one to pull it back down through.
