hoe do i get to the adaptive control board on a model msd2756aew? may tag refrigerator
see the 3 messages on page 2 starting with the one from RegUS_PatOff on: Sat Sep 24th, 2005 20:12
Posted 03 November 2005 - 03:30 AM
Posted 06 November 2005 - 08:37 PM
Posted 06 November 2005 - 09:12 PM
Posted 07 November 2005 - 10:41 AM
Posted 07 November 2005 - 12:34 PM
Posted 28 November 2005 - 06:26 PM
Posted 28 November 2005 - 09:35 PM
Posted 25 December 2005 - 07:42 PM
I have a Maytag MSD2756AEW and had the same defrost problem.
I drew a schematic of the ADC and found the cause and fix for the "buzzing relay"
It's a bad electrolytic capacitor, C2, 22uF@50v
Try jumpering in a good one across it. (there is a protective coating over the entire board)
Watch the polarity and also be careful, the minus (-) side of the cap is connected to L1 120v HOT side of the power line.
I drew the schematic with MS Paint, and will soon draw it with a schematic program and upload it here.
also, neither the compressor nor the defrost heater will work when the temp control is turned down (but the relay will still energize) try it at max cooling setting.
Posted 01 January 2006 - 09:27 PM
Posted 16 January 2006 - 05:44 AM
Posted 21 January 2006 - 03:20 PM
Posted 22 January 2006 - 09:28 AM
Posted 25 January 2006 - 06:48 PM
Posted 25 January 2006 - 06:58 PM
I have a Maytag Wide by Side model# MZD2766GEW series 10. I ohmed the thermostat and it is opening and closing correctly. I ohmed the defrost heater- tested Ok. I then jumpered the heater and it heated just fine, so I determined that the ADC was defective. I checked all the voltages to the board to make sure it wasn't a connection problem and they were all correct. I shorted L1 and the Test but the unit still doesn't go into defrost. My temp control was closed at the time, which according to the information I read is right. I do not get any buzzing of the relay. I purchased a new ADC at a local dealership, but it looked used and has the same problem my original one does. The dealer refuses to refund or replace the ADC, so I am trying to find a way to repair the PCB. From what I have read, C1 seems to fail. There is alot of information on replacing the C1, but does anyone have any information about a replacement relay?
Posted 27 January 2006 - 04:12 PM
Posted 31 January 2006 - 03:15 PM
Posted 01 February 2006 - 07:51 AM
Posted 04 March 2006 - 12:35 PM
Posted 06 March 2006 - 12:27 PM
Posted 12 March 2006 - 05:17 AM
Once in a while you can get shown the light, in the strangest of places ...
I've been having an on-going battle with defrosting my Jenn-Air JCD2389GES side-by-side, knowing all along that blow-defrosting it was putting off the inevitable. A friend who is a Maytag dealer several hundred miles away sent me an ACD to try to solve the problem. I installed it yesterday, but without the expert guidance here, I'd probably have been scratching my head much longer than necessary trying to figure out where the ACD was located and how to change it. Bon sai! mighty Samurai for once again imparting your wisdom!0 members, 0 guests, 0 anonymous users
