Learn how to be your own tech line...
ralphwhitfield
GE Profile Dryer Squeals.
9 posts in this topic
Help!  GE Profile dryer, runs fine until you put clothes in it and then it starts squealing.
My first thought would be the drum bearing (roller?).  Is this easy to get to and fix or is it a real pain and should I invest in a repairman?
Where would I find disassembly instructions?
Ralph
This being the new style G.E. dryer I would suspect the front glides are worn down and the drum is rotating and digging into the plastic drum support.
Well, I opened up the dryer when I got home and lo and behold I had 1 and a 1/16th of my gliders. I'm going to get a new set tomorrow. I'll give that a try before I break into the bearing.
I propped the drum up and will leave it open over night and clean up the inside in the meantime.
Thanks, I'll get back if this doesn't fix it.
BTW, the disassembly instructions are great.
Ralph
Thanks for letting us know, and please tell us how this comes out as it will help others also. :cool:
My apologies for taking so long and getting  back...busy weekend.
I decided to get the plastic part that the glides attached to as well, but it won't be in until Tuesday, but I went ahead and installed the glides in the old part and lo and behold it eliminated the squeal!!!
Yeah!!!  $12 in glides and the problem solved.  Another $30 or so for the plastic part the glides mount to and eveything should be back to normal or as normal as things get in my household anyway.
The replacement took only a total of 15 minutes or so.  The hardest part is getting the top back on.
Anyway...thanks for all the help.  The disassembly instructions helped immensly.
This repair dropped from a 3 SUDS down to a single SUDS, at least in my opinion.  Of course, I haven't changed out the other part yet.  That's on Tuesday night ;)
Ralph
Yes, these "New and Improved" dryers are not user friendly as the heavy drum with the wet clothes just eat these things they call glides and there goes the drum eating the plastic bearing ring.  Thanks for letting us know this solved the squeeking problem. :cool:
True, the bearing rim was/is shot.  However, it took until almost all of the glides were gone before it started squealing.  That is something.  I feel very fortunate to be out of the situation with only a $49 parts repaire bill instead of tacking on another $60+ for a repairman to come in and fix it.
(Of course, now that I have gone and said that something else will go wrong!  ;))
Ralph
;)  Yes, your heating element will break and that will require removing the drum which requires removing the drum belt and reinstalling this belt onto the dryers from HELL.....
