  • Announcements
fredvp
Hotpoint inner tub removal
13 posts in this topic
Hi
My tub seal has gone bad on my over-10 year old Hotpoint
washer. Its a model # wlw4700B.
I have got the top off and the agitator out. Now
I'm stuck.
To get out the inner tub it looks like some sort
of assembly has to come off on the bootom of the shaft
inside the inner tub. Its a plastic thing that
fits over the shaft on the bottom. Probably covers some
screws on the bottom. Its round and seems to have some
sort of spring inside.
How to get this plastic gizmo off is the mystery. Any
ideas anyone?
Fred
Hummm, thatis just a plastic hub cover, just push on the tab and the thing pulls right off.  Usually the tab is broken and the thing falls off on its own.  If you break it getting another will be cheap, should be less than $5.00
Dude it's toast.
   Maybe one day I'll sit down and finish this.  Even incomplete, it has the answers in which you seek.
Jedi, Don't write this one off yet, it's one of the old sytle good G.E.'s
That plastic agitator bushing that covers the 3 tub bolts is probably all gunked up with old fabric softner crude, just move that little tab you see one way or the other while wiggling and lifting up on cover. It should come out with a little work and if it won't just break it out and replace with a new one.
When you do get it off, make sure to use a good 12-point socket on those tub bolts or you will end up rounding the heads off.
You will most likely find one of three problems that might be causing your leak.
1) If the leak is real bad, dumps water out as fast as it goes in, then the tub boot has probably just pulled loose out of place and will just need to be reinstalled.
2) If small leak, something has put a hole in the rubber tub boot.
3) You have small rust holes in the bottom of your tub, this is not uncommon at all on this old of G.E. machine, they have a tendency to accumulate sediment and pins and junk around the tub boot and then the tub will rust through.
Let us know what you find and then we can help you further.
Looks like the larger clamp had worked
loose so there was no seal. I tightened
up the clamp and everything seemed fine
except for a small drip. I ordered a new
seal and will clean up the mating surfaces
before putting in the new one. Hopefully
that should fix the drip.
Fred
Good, the ridges on the tub boot were probably flattened and the new boot will have good ridges. Cleaning the transmission top will help stop the leak.
Hi all
I received the new boot and installed it. In tightening up the lower clamp I had a problem. It seems as I would get the
lower clamp real tight the boot wood ride up and off its seat. This could have been the cause of the original failure, as when they put the washer together maybe they couln't tighten up the lower clamp enough so over time the boot slid off its seat. I applied some silicone sealer to the gasket, installed it, let it dry, and then tightened it up. This time the seal stayed put. No leaks yet and back in business!
Fred
:party:
This is an old, cold thread.  I have the same problem.  The washer is a Hotpoint WLW4700B.  I have removed the agitator by turning the tabs on the top about 30 deg and lifting the agitator off of the inner assembly.  The inner agitator assembly (which I think you refer to as the agitator bushing) has no obvious way of unlocking it.  I do not see any tabs that are mentioned in the previous advice (could you be referring to the tabs on the outer agitator assembly?)
The inner assembly (picture attached) does have two small (~3/16") holes about 1/2 way up its height.  I probed the holes with an allen wrench but did not feel anything like an allen socket or screwdriver slot.  Is it pressed on the drive shaft?  Can I pull up on the skirt at the bottom?  How hard should I pull?
I don't want to break this part because it costs $95 on your parts website (and it isn't in stock).
What am I missing?
That is the inner agitator, the hand wash one, if there is a screw in the center of the top, remove it, then it is just brute force to pull it up...we use an agitamer to remove these but you might put a strap or rope  under the bottom, attach it to a 2x4 and tap it up with a hammer...
Observe the technique of the master:
gewasholderstyle14.jpg?dc=4675487824038713777
