Bubbamill
Whirlpool washer leaks during spin cycle
6 posts in this topic
Help!
This is not your basic leak. My three year old wahser has always does this to some extent, but it seems to be getting worse. Here is my problem:
Whirlpool washer. model #LSQ9110LW
When the machine enters the spin cycle, the tub starts spinning at the same time the pump starts draining. If the water level is high and the load is medium sized, then water spills over the edge of the tub as the spin starts. If the load is big enough, then the tub won't spin until some of the water has drained out and all is okay. But with a lighter load, the spin causes the water to ride up and over the side of the tub. This causes water to run down the inside of the cabinet and onto the floor. My drain standpipe is high; right at the maximum of 72 inches. I have tried raising and lowering the standpipe, but it has little effect. The problem seems to be that unless the load is heavy, the spin happens too soon before the water has time to drain. I have used several other washers in this same location over the past 25 years and this is the first one to have this problem. Any ideas??
Assuming this is your basic Direct Drive washer, this does not make sense.  The washer drains then spins after it is empty.  Even the first DD washers with direct into drain, that drained and spun at the same time never did this.  They changed them to nutral drain around 1985 or so since this took the strain off of the motor and coupler, having them drain first then spin.  Why you are draining and spinning at the same time on a 3 year old W/P washer is beyond me.  But without the model number cannot tell if you have a different system.
Thanks Pegi,
As far as I can tell, it is model #LSQ9110LW.
If I stand next to the washer as soon as it enters the drain cycle, I will immediatly see water running out from under the cabinet. If I quickly open the lid, I can see that the tub is spinning and the water is sloshing over the tub edge. Of course opening the lid stops the cycle and the water falls back down to its normal level. This problem always happens in the perm press cycle and sometimes happens in the regular cycle. I don't know if the cycle has anything to do with it or if it's just that I tend to use a larger heavier load in the regular cycle.
Never heard of this.  This washer should drain, then pause then spin after the washer is empty.  Even if the neutral function was out in the transmission it would still drain and spin the water out at the same time.  It sounds like something is blocking your washer from draining all of the water in 120 secnds.  Start checking where the blockage might be in the hoses, pump areas.
Thanks, I'll take a look. I don't believe there is any blockage based on the flow of water coming from the drain hose. The cycle appears to go from agitate then a brief pause (~1 second) and then the motor starts again and you hear the water start to drain. At the same time you hear the water start to drain, the tub begins to spin. Since the spin and draining appear to start together, there is hardly any time to drain any water before the tub is spinning and forcing the water up and over the tub rim. COuld it be a problem with the timer? Maybe the timer contacts that start the drain action are somehow starting the spin too? It's almost like the time in between the drain and the spin is missing?
Yes, you should have the 2 second pause at the end of drain to set up the transmission to spin.  However before the neutral transmission the drained and spun at the same time and the water did not go over the top. Wonder if the gasket is missing under the splashguard???  Perhaps you need to replace the timer to get the second pause?
