Fisher&Paykel DW920 dishwasher
2 replies to this topic
#1 DianeB
DianeB
  • 1 posts
Posted 10 April 2005 - 03:01 AM
We bought a new Fisher&Paykel dishwasher today:).  A F1 fault came up after we had a small blockage at the end of the drain hose:( - now cleared:). The problem is now the machine is bleeping and displaying the F1 fault :X- the water has drained away:?.
How can I reset the F1 problem?
Any help would be very welcome.:)
DianeB
#2 mopar X
mopar X
    Yamabushi
  • Master Appliantologist
  • 76 posts
Posted 10 April 2005 - 04:30 PM
On the earlier models you pressed and held the keylock button till it beeps which should clear error should work on yours also
#3 Guest_Joephedi_*
Guest_Joephedi_*
  • Lurking at the Threshold
Posted 30 May 2005 - 05:51 PM
I had the same trouble, called a tech and he had to just tighten the screws holding the black wheels for the trays to slide in and out, this is in the inside of the dishwaher.
If lose it lets the water out and cause to flood.
Good luck
