  • Announcements
NeedaFix
GE Double Wall Oven Problems
6 posts in this topic
Model Number - JTP56BD1BB
Serial Number - FD6 20167Q
Here is my problem:  I have a 3 year old GE Profile double wall oven that about 2 weeks ago had the dreaded F0 error message on both sides of the display. I saw on a online repair clinic that the problem was the RCL board. OK so I ordered and installed a new one. Worked great for 6 days, then I started getting the F0 error on the right side on the display. I called the repair clinic and they said It was still the RCL and sent me a new one under warranty. Great worked great for two days. Now I do not get a F code but the oven starts to heat up then shuts down, I can hit clear bake and then temp again, same thing runs great for anywhere between 2-10 minutes then shuts down again. Oh  the oven light comes on when the door is open but  not by the oven light switch. Any help would be greatly appreciated.
Steve
Let the Force guide you on this journey quest for knowledge.
Update, I have cleaned the ribbon cable and it seemed to be working. The light switch is working and my wife can use it.
Now it must be haunted, yesterday evening the oven just turned itself on. Then again this morning, the funny thing is the temperature that it goes to was not the last  temp used on the oven.
Thanks for any help
One with the force you are not.  Sure are you that it is RCL board?  Mean did you ERC?
Yes, sorry it was the ERC that was replaced.
Yes you are right I am not a appliance repairman that is why I was writing a post on this forum.
Update, I did clean the ribbon cable with an eraser and now the oven works but now I have a different problem. The unit will turn itself on for no apparent reason.  I guess I will replace the touch pad. I hate to just spend more $$$$$$$$ just to see if this will fix it.
     Necessary it is not, to be an appliance technician, to be at one with the force.   If you had clicked on the word "force" in my 1st post in the thread, you would have been taken to 2 message threads.  Both have the same model oven as you and both needed keypads and ERCs.  Get your keypad ASAP.  I believe if left too long, your flaky keypad can damage your new ERC.
